Max. Outside Calls in Conference Call
How many outside calls can we make in a conference call with CME and CCM ?
thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Max. Outside Calls in Conference Call
Hi Okan,
Before Cisco Unified CME 4.1, support for conferencing is limited to three-party ad hoc conference calls using a G.711 codec.
In Cisco Unified CME 4.1 and later versions, multi-party ad hoc and MeetMe conferences allow more than three parties.
From this excellent CME doc;
Cisco Unified Communications Manager Express System Administrator Guide - Configuring Conferencing
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1010335
Hope this helps!
Rob
there is no fixed limit to this as it depends on CFB being used, if using G711 and SW CFB you can go as far as 42 per conference if you configure it that way.
if using HW CFB up to 8 participants with different codecs, if SW CFB + XCODER depends on stream codec and xcoding resources along with max number of users per conference
read the SRND media resources chapter for more info
java
if this helps, please rate
java
www.cisco.com/go/pdi
what about call manager express?
built-in 3 way conference, HW same as CUCM
plenty of info available on CCO and NetPro if you dig a little
java
java
Hi Okan,
Hope this helps!
Rob
335
