Maximum call duration in dial-peer settings
sbraychuk
How I can set maximum duration to outgoing call? Can I do it?
5 Replies 5
mightyking
Level 6
Level 6
Note this setting will apply to all calls and can not be set for a singl call. If you're using CCM go to:
CCMAdmin--> Service --> Service Parameter --> Cisco CallManager -->Advanced
Default: 720.
Unit: min.
Minimum: 0.
Maximum: 35791.
Unfortunately with CCME there's no easy solution. You need to develop a TCL script.
MK
Yeah, MK. I have understand it also.
Have you the example of TCL script?
Try to contact paolo bevilacqua (Netpro). He can help you. Here's where you can find the detail about him
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_user_info%26location%3D.ee6c829&author=p.bevilacqua
Mk
Thank you.
Hey, did you managed with this? Did you developed a TCL script? I also need this functionality (max call duration). What do you think, will Cisco integrate it in the future IOS releases?
