Maximum call duration timer for a device
Cisco CUCM 9.1
Does anyone knows , is it possible for  the following service parameter in CM (Maximum call duration timer) only apply to a device(s) and not apply to global setting.
I have a need to keep multiple end points which run cameras to be active  and not end the call. Need it to be running  24/7 . IF this is not possible, are there alternative opitons or a 3rd party solution.
JayP
Everyone's tags (4)
Re: Maximum call duration timer for a device
No way to do what you want in CUCM, the parameter affects ALL calls
java
if this helps, please rate
www.cisco.com/go/pdi
Jaime,
If this is not avaiable. What are my options ?
JP
I don't believe there's any for internal calls, for external calls, most likely TCL scripting.
java
www.cisco.com/go/pdihelpdesk
java
414
