Maximum number of H.323 and SIP trunks in CUCM 7
Dear Networkers,
I would like to know what is the maximum number of H.323 trunks supported with CUCM 7
I would like to know what is the maximum number of SIP trunks supported with CUCM 7
Can you please help?
1 ACCEPTED SOLUTION
Re: Maximum number of H.323 and SIP trunks in CUCM 7
SRND and config guides are always the 1st place to look for this kind of data
A cluster consisting of MCS 7825 or MCS 7835  servers can support a maximum of 600 H.323 devices (gateways, trunks,  and clients), digital MGCP devices, and SIP trunks.
A cluster consisting of MCS 7845 servers can  support a maximum of 2100 H.323 devices (gateways, trunks, and clients),  digital MGCP devices, and SIP trunks.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/callpros.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
283
