Maximum number of route-patterns of CallManager cluster
jjia
Level 2
Level 2
Just wondering if there is a guideline for the maximum number of route-patterns of one callManager cluster from the performance perstective of view.
CCM 4.1(3), Two MCS7825 servers for one cluster.
JJ
jbarcena
Level 9
Level 9
It depends on the load that each server supports, and is not an information for only the Route Patterns, you need to sum all the devices:
Maximum Number of Devices per Server Platform:
- MCS-7845 --> 7500
- MCS-7835 --> 2500
- MCS-7825 --> 1000
- MCS-7815 -> 300
Device wights determine the maximum number of physical devices that can be registered to a
CallManager subscriber. Some IP Pone models support multiple lines (directory numbers or
line appearances). Many IPT deployments have directory numbers that are shared across
multiple IP Phones and a large number of dial plan entries that include route patterns;
translation patterns require an extra amout of resources (CPU,memory) on the CallManager.
Dial plan weights provide the limit on the number os fuch dial plan entries configures in
a CallManager subscriber. Dial plan weight calculations provice guidelines to size the
cluster .
Base Dial Plan Weights:
IP phone device (excluding lne appearances) --> 5
Unique line appearance --> 5
Shared line appearance --> 4
Route Pattern --> 2
Translation Pattern --> 1
Thanks for your information. But I am not sure how to calculate those route-patterns against to the number of MCS7825 supported 1000 devices.
For example, if I have 2500 route-patterns, with 300 IP Phones, each has two lines are configured. How many of devices will be calculated?
JJ
