Maximum number of zones a gatekeeper can support
Dear All
I want to deploy Cisco Gatekeeper in my Company's IPTelephony infrastructure as we have more that 60 small IPT clusters at present. I am planning to use 3825 or 3845 ISR. Please let me know how many zones can be configured in a gateleeper. I heaf it is 100. Please correct if I am wrong.
Thanks&Regards,
Siraj
2 ACCEPTED SOLUTIONS
Re: Maximum number of zones a gatekeeper can support
100 zones is correct.
You can define up to 100 zones in a single  gatekeeper.
http://www.cisco.com/en/US/partner/docs/ios/voice/h323/configuration/guide/vh_h323_gwconfig.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Silver
You are correct - from the 8.X SRND:
A zone is a collection of H.323 devices (such as endpoints, gateways, or MCUs) that register with a gatekeeper. There can be only one active gatekeeper per zone, and you can define up to 100 local zones on a single gatekeeper.
Cheers!
Art
java
java
Thank you very much for the info and advice.
Best Regards,
Siraj
Silver
Cheers!
Art
Best Regards,
Siraj
874
