Maximum PoE 802.3af distance 15.4W
I've got a new wiring project coming up shortly that may tax the limits of cat5e standards.
I am having trouble locating documentation that says what a theoretical maximum distance for a 802.3af class 3 device will be.
Has anyone run into problems with voltage loss over long distances? Will I be OK as long as the wire passes a fluke cat5e test?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Maximum PoE 802.3af distance 15.4W
Hi JP,
The standard 100m ethernet rules (90m drop + 10m patch/cross connect) still apply here. If the cables fall within this standard and pass the testing with good results you should be good to go.
Hope this helps!
Rob
Hi JP,
Hope this helps!
Rob
Thank you for your swift reply, Rob
2346
