Community Member
Maximum speed for modem/fax on a VG224
Hi all,
We got a project with a customer who wants to connect a few modems / fax machines with a VG224.
What are the up an downs with this solution
(CCM 5.x -- SCCP -- VG224) ?
Can the VG224 provide a modem speed up to 56Kbbps?
Thanks for your time.
Greets,
Norbert
1 REPLY
Hall of Fame Super Gold
Re: Maximum speed for modem/fax on a VG224
No, as far as I'm aware, codec G711u, doesn't not supports modem or fax faster than 28.8.
If you want higher speeds, use FXS ports in the router.
489
