MCP with fractional E1
we have a 2821 configured as a MGCP GW on CCM 4.1(3). The gateway during normal operation does not facilitate the in or outbound calls - another GW off site does, however when in SRST it should, but when calls are placed - only an engaged tone is heard.
I have had problems in the past using a fractional E1 (only 16 channels in use) and have had to use H323 instead. Any one had similar problems and ways to solve the issue?
cheers.
1 ACCEPTED SOLUTION
Re: MCP with fractional E1
What does a debug isdn q931 show on the gateway ?
If it shows requested circuit or channel unavailable then I suspect you need to change the channel selection order in the gateway config page.
Paul.
Hall of Fame Super Gold
Are you using ISDN PRI ?
Can you better describe the problem and post router config ?
hi chaps,
ISDN PRI - yes. Problem is that when a call is placed from an IP phone they get the busy tone.
I dont get anything out of the ISDN Q931 debugs, so it looks as if the call is not being placed to the controller.
Paul.
I had a similar problem.
Fractional PRI is not supportet with mgcp yet.
When you use srst the router will go out on the higher pri channel.
Possible you can experimente with this:
-Under the D channel, enter the following command:
isdn bchan-number-order ?
ascending
descending
Sebastian
149
