MCS 7800 sizing
Hello
I didn't find a calulation for MCS 7800 servers and the recommend amount of user for callmanager 8.6. Does anyone have a such table? My installation  have 200 users.
Pascal
3 ACCEPTED SOLUTIONS
Green
MCS 7800 sizing
Pascal,
There is a proper Cisco CUCM sizing tool at
http://tools.cisco.com/cucst/faces/
You do need to log in, I just need my CCO credentials but it may that
you need to be a partner company etc.
Have a look anyway.
Alex
Regards, Alex. Please rate useful posts.
MCS 7800 sizing
Table 8-3     Maximum Number of Endpoints per Server Platform or OVA  Template
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/callpros.html#wp1287901
For that amount of users depending on what you need you might consider a CUCMBE, sizing is in the same doc a few scrolls below the link I provided.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
MCS 7800 sizing
CUCM 7.x SRND guide has the details but surprisingly that table is removed from CUCM 8.x SRND guides. Neverthless, the capacity limit is still applicable with 8.x. http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/callpros.html#wp1059559
Please rate helpful posts.
GP.
Green
MCS 7800 sizing
Pascal,
Have a look anyway.
Alex
MCS 7800 sizing
java
java
MCS 7800 sizing
GP.
569
