Community Member
MCS 7815 - Alarms
Anybody know what is the alarms ! with ambar led on MCS-7815 IBM?
Green
Re: MCS 7815 - Alarms
Normally amber light makes reference for failed drive, You may run some HW diagnostics.
you can use IBM tools that came with the server.
Community Member
Hi , i have the same symptom. The CCM works fine, but the led amber is lighting. Do you know where downloading the IBM Tools?
185
