MCS-7815-I1-CC2/IPC3 at 2,5Ghz instead of 3,06Ghz
I've got a MCS-7815-I1-CC2/IPC3 IBM 306 Platform, boot at 2,5Ghz instead of 3,06Ghz.
I have CCM version 4.2.3 and I want to upgrade to 6.1 but verification hardware failed due to speed cpu.
- I have upgraded bios with last firmware from IBM : without success.
- I have open the cover to see if there are jumpers : no success.
- I want to change cpu setting on bios
(Advanced Processor Options) : impossible.
How to change theses settings ?
Best regards.
Green
Re: MCS-7815-I1-CC2/IPC3 at 2,5Ghz instead of 3,06Ghz
This sounds like a problem with the bus on the system board. I have seen replacing it resolve this issue before
Thank You for you answer.
I just have another question : what is the original frequency of the RAM on this type of server? I've remarked that I've got PC2700 (DDR 333) on the server and I think that it sells with PC3200 (DDR 400) ?!
Can you confirm this ?
Thank you.
99
