MCS-7835 additional Memory needed for 6.0?
I ordered part number CCM 6.1 MCS-7835-H2-IPC1 server for a call manager 6.1 upgrade.
I was quoted part number MEM-7835-H2-1GB.
Is this additional memory needed for the CCM install?
Hall of Fame Super Silver
Re: MCS-7835 additional Memory needed for 6.0?
Yes, you do not need it, but having more memory in server can not hurt and will actually come in useful.
Chris
Hi friend,
As Chris said, its not necessary.
Two links that may be useful, if you don't have them yet.
CUCM 6.1 Release Notes:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html
"Some servers that are listed in the compatibility matrix may require additional hardware support for Cisco Unified Communications Manager Release 6.1. Make sure that your server meets the minimum hardware requirements, as indicated in the footnotes of the compatibility matrix. Cisco Unified Communications Manager requires a minimum of 2 GB of memory, 72 GB disk drive, and 2 GHz processor."
MCS-7835:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_data_sheet0900aecd80586038.html
The MCS-7835-H2 ships with 2GB of memory installed.
- adrián.
Thanks for the information, I just wanted to make sure that I did not recieve any hardware conflicts when installing.
151
