Community Member
MCS-7835-H1-IPC1
Is this server
MCS-7835-H1-IPC1
supported by Cisco Windows 2000.2.7
Community Member
Re: MCS-7835-H1-IPC1
Hello Rocampo ,
Yes it is supported , we just updated the OS couple of weeks ago to this Release but you will need first to upgrade to ( win-OS-Upgrade-K9.2000-4-4a ) and then to ( win-OS-Upgrade-K9.2000-2-7 ).
Please rate the Post if it is helpful.
M.Tag
Community Member
so youre saying the installer kit will detect the hardware ?
Community Member
Hello Rocampo ,
To pass the HW Detection Phase , use the HW Detection CD Shipped with the CCMVersion 3.0 or 3.3 , Then Install the OS Upgrade Patches with the same order i mentioned to you.
1 - HW Detection ( The one shipped with 3.X )
2 - Disk 2
3 - OS Upgrade Patch 1
4 - OS Upgrade Patch 2
M.Tag
181
