08-20-2009 12:10 PM - edited 03-15-2019 07:27 PM
two CM7 MCS7835's. I need to know if the NIC supports Gig. I can show network eth0 and see what its set to, but cant see its capabilities like I can in the windows world with device manager. thanks
Solved! Go to Solution.
08-20-2009 12:38 PM
The data sheets have that kind of info:
Cisco MCS 7835-H1
Network Connectivity
Network Interface Card (NIC)
Dual onboard 10/100/1000
Connector
Two RJ-45 connectors on rear of server
10BASE-T Cable Support
Categories 3, 4, or 5 unshielded twisted-pair (UTP) (2 or 4 pair) up to 328 ft (100m)
100BASE-TX Cable Support
Category 5 UTP (2 pair) up to 328 ft (100m)
1000BASE-T Cable Support
Category 5 UTP, 5E UTP,or 6 UTP (2 pair) up to 328 ft (100m)
java
if this helps, please rate
08-20-2009 12:15 PM
One thing that would be important to know is what the letters after MCS7835 say.
I don't know about all 7835 platforms, but my i1's are all the same, Gigabit Ethernet.
Hope this helps.
08-20-2009 12:32 PM
7835-H1
08-20-2009 12:38 PM
Cisco MCS 7835-H1
Connector
java
