Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
MCS-7835-I2, how to setup IBM system mgmt port
How to setup the system management port in MCS7835-I2 which IBM platform? or URL to refer.
Thanks in advance,
Re: MCS-7835-I2, how to setup IBM system mgmt port
MCS7835-I2 (IBM) has two Ethernet NIC and one system management port. My question is how to configure the system management port which I think analogue to HP's ILO port.
I know how to configure HP iLO. please guide me how to the IBM's system management port in MCS box.
Thanks in advance,
Silver
I would open a TAC case for that. The support matrix for hardware and software (I think only 5.0 and 6.0) whether you can use it for upgrades (I know you can't use HP's ILO for upgrades for some reason) is weird.
I opened a TAC case for the RSA a year or so ago (can't remember the details) and it gave me a headache, so I told the customer to either use VNC for what they wanted to do or buy an IP KVM switch (some of which may also have issues especially during upgrades.)
I just use VNC for management. The idea sounds nice to be able to see POST, etc, but the real world makes it too complicated to want to use.
Did you ever figure this out?  I am new to IBM servers and need to know
how to setup the RSA II to obtain ILO like functionality.
Frank
So if I understand correctly you want to do something similar to HP iLO with the IBM server. In IBM terminology, this feature is called IBM RSA II Slimline, this their name for remote managerment via IP.
Please refer to the following doc from IBM for info on how to configure and use the RSA on this server.
ftp://ftp.software.ibm.com/systems/support/system_x_pdf/43w7827.pdf
Has any one been able to get the remote control feature working?
I have exactly the same question. This is for UCM and UXN 8.0
4281
