MCS 7845 H2 not bootable from DVD or CD
Hello Community, I stuggle arround w/ this problem the whole morning. I have a MCS 7845H2 with RAID and five Harddisk and a DVD ROM. I will boot from a bootable 8.6.2 CUCM DVD. In BIOS of the server is all fine configure. At first position is DVD in boot sequence.
But they wan´t to start from 8.6.2 CUCM DVD, no Chance! They always start from HDD.
Any help are appreciate. Any Idee?
Thanks in advance.
HTH, please rate all useful posts and right answers.
1 ACCEPTED SOLUTION
VIP Purple
I could some bugs related to MCS and other CUCM version but that is not exactly to your Hardware/CUCM version.
can u try using another Call manager media/version or application [unity connection] to find the cause?
regds,
aman
Re: MCS 7845 H2 not bootable from DVD or CD
are 100% sure the DVD is bootable number 1.
Number 2 why don't you mount the DVD under edit VM options and select the check box to start and connect on power up.
Then you open the console view via vSphere and make sure it starts from the DVD.
or here:
Voice CCIE #37771
Are you sure you've got a bootable CD there? The standard ISOs you download from Cisco.com aren't bootable.
Have your tried other CDs?
GTG
Please rate all helpful posts.
Hello, thanks for your answer.
No Vmware! 8.6.2 on MCS 7845 "Hardware".
Yes, the DVD is bootable, I double check in another PC.
The DVD is shown in Bios and at first position. But at second controler connected and I can´t move the controler on first position.
have you tried my methode in the vsphere client as per my screenshots?
Voice CCIE #37771
Hi, as I write in my last answer, I have "NO VMWARE". The 8.6.2 should be install at the HW 7845H2 w/o VMWARE. But the Server will not boot from this DVD. They boot the old Version 7.1 from HDD. NO Chance to boot from DVD.
But I have try DVD in Vmware Player, the DVD is bootable!
Still not solve and may be community have an Idea.....
Thanks ikn ahead
the ISO's you download from CVisco.com is bootable until ver 7 yes the rest is not bootable only on VM Ware can one get it bootable.
Voice CCIE #37771
VIP Purple
regds,
aman
Really thanks for that note! I try a W2K3 Server and 8.0.2 CUCM DVD at 7845H2 HW and it boots from DVD.
The medium 8.6.2 CUCM still not works in this 7845 H2 HW. But it works on other HW.
Confusing.
Thanks for your support.
VIP Purple
what is the exact MCS Hardware u are using ?
regds,
aman
7845H2
VIP Purple
Hi ,
Model has to be like
MCS7845H2-K9-CMA1
MCS7845H2-K9-CMA2
MCS7845H2-K9-CMB1
MCS7845H2-K9-CMB2
MCS7845H2-K9-CMA1D
MCS7845H2-K9-CMA2D
MCS7845H2-K9-CMB1D
MCS7845H2-K9-CMB2D
MCS7845H2-K9-CMC1
MCS7845H2-K9-CMC2
I was referring the Hardware compatibility matrix to find the CUCM support.Can u confirm which model u are using ?
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
regds,
aman
MCS7845H2-K9-UCB1 , it is not at this matrix. It seems it is a CUC Server.
VIP Purple
yes , you are correct  it is a Unity Connection server.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps6509/data_sheet_c78-491743.html
Cisco Unity Connection 7.x Currently Shipping Supported Platforms
Cisco MCS 7825
Cisco MCS 7835
Cisco MCS 7845
Cisco MCS 7825I4-K9-UCB1
Cisco MCS 7825H4-K9-UCB1
Cisco MCS 7825-I4-ECS1
Cisco MCS 7825-H4-ECS1
Cisco MCS 7835I3-K9-UCB2
Cisco MCS 7835I2-K9-UCB1A
Cisco MCS 7835H2-K9-UCB1A
Cisco MCS 7835l2-K9-UCA1A
Cisco MCS 7835H2-K9-UCA1A
Cisco MCS 7835-I2-ECS11
Cisco MCS 7835-H2-ECS11
Cisco MCS 7835-I2-ECS22
Cisco MCS 7835-H2-ECS22
Cisco MCS 7845I3-K9-UCB2
Cisco MCS 7845I2-K9-UCB1A
Cisco MCS 7845H2-K9-UCB1A
Cisco MCS 7845l2-K9-UCA1A
Cisco MCS 7845H2-K9-UCA1A
Cisco MCS 7845-H2-ECS13
Cisco MCS 7845-H2-ECS24
Cisco MCS 7845-H2-ECS3
Cisco MCS 7845-H2-ECS45
Cisco MCS 7845-I2-ECS13
Cisco MCS 7845-I2-ECS24
Cisco MCS 7845-I2-ECS3
Cisco MCS 7845-I2-ECS45
regds,
aman
502
