Community Member
MCS 7845 I3 booting issue
Hi ,
We have procured MCS 7845 I3 for fax server installation. Installed OS and found working fine. But recently we had an HW Audit in which they have removed the HDD while it was running to check whether RAID is working or not. From then, I am getting this error " Pxe-e61:media test failure. check cable Pxe-m0f:exiting broadcom pxe rom " and not able to boot. Kindly suggest me the next step and any solution if available.
Sankar.
Everyone's tags (4)
Community Member
In most cases the error message appears due to hard drive failure
The system is trying to boot from network since it is unable to detect the hard drive and thus showing the error message regarding PXE
plz go to bios and check is it listing the disk or not
Community Member
Hi!!
Righ now I have the same problem with a MCS7825I2...I maked an upgrade from CUCM 5.1.2-1000 to 5.1.3-7000 and then switch version un Publisher , but when the server is booting...says this error...Pxe-e61:media test failure. check cable Pxe-m0f:exiting broadcom pxe rom...
The suscriber its up, with version 5.1.2-1000, but I don´t have DBase backup....Can I backup DB from the suscriber to a sftp server?
Thanks in advance!!
721
