Community Member
MCS Hardware failure
I Have an MCS 7800 (end of life) that has give up the ghost. Red light is flashing on the front panel of the server - won't boot.
To cut a long story short, I am wondering if I could buy a second hand server of the same model and put my existing hard drives in (assuming they are ok - I think they are)?
Will I have problems with licenses etc?
As you can probably guess, I'm no voice expert so any info would be much appreciated, I know my description of the problem is rather vague if anyone wants more info I will do my best to elaborate.
Cheers,
Rob
1 REPLY
Purple
Hi Rob, you will need to have
Hi Rob,
What is call manager version u are using?
you will need to have licneses re-hosted since MAC -address would get changed.
regds,
aman
62
