Community Member
MCS Operating System version and patchs status
How can I find the status of my operating system (Windows 2000 and CallManager 4.1.3) so that I can properly update to the latest version? I also do not want to cause problems by applying updates and patchs that are wrong or overlap. Also, Is it wise to update a Unified Communications Server or other system if there are no problems?
Thanks.
VIP Purple
Re: MCS Operating System version and patchs status
You can find the current OS/SR by clicking Start > Cisco OS Version. I believe it is wise to keep up with the latest patches/SRs even if you are not havig problems. Take a look at the following post regarding patching CCM/Unity.
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dddb705/0#selected_message
Hope this helps.
Brandon
Community Member
Hahaha!!
Thank you so much.
I never noticed it before!
263
