MCS Server Serial Number via SSH
Hi! Can I get the serial number of an HP MCS server running CM 5.1 through the SSH session? I tried all the show commands and can't find it anywhere.
Re: MCS Server Serial Number via SSH
Try the show hardware command.
-- adrian
Here's my "show hardware" output:
admin:show hardware
HW Platform : 7845H2
Processors : 2
Type : Intel(R) Xeon(R) CPU 5140 @ 2.33GHz
CPU Speed : 2333
Memory : 4096 MBytes
Object ID : 1.3.6.1.4.1.9.1.586
OS Version : UCOS 2.0.1.0-71
RAID Details :
Smart Array P400 in Slot 1
Logical Drive: 1
Fault Tolerance: 1+0
Heads: 255
Sectors Per Track: 32
Cylinders: 17562
Stripe Size: 64 KB
Status: Ok
Array Accelerator: Enabled
Has Data On Drive: True
Unique Identifier: 600508B10010443953554B4452500004
Preferred Controller Chassis Slot: 1
Logical Drive: 2
Heads: 255
Cylinders: 17562
Stripe Size: 64 KB
Status: Ok
Unique Identifier: 600508B10010443953554B4452500005
admin:
I don't see it anywhere...
show hardware should show it:
Show Commands
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/5_1_1/iptpappa.html#wp1026032
Maybe you're hitting a bug
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
I see what you mean. The documentation does say that command will show the serial #.
However, I am not able to see it via an SSH session w/ show hardware or even show tech all. [CUCM 5.1.3]
Is it a strict requirement to get the serial # thru SSH only?
I see my serial # in the web interface:
https://myhpmcsserver/iptplatform
then select Show>Harware
I also feel duty bound to warn you that this serial # is one of two that I see stamped on my HP MCS servers. Not sure what the other one is for..
Tony
no, actually most of the times i ask users to get me the SN if needed thru the webadmin and it's the same thing. usually it's easier to ask it that way.
javalenc
java
531
