Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
MCS7835 difference
I have in project many 7835 servers.
Is there any difference between them?
or I can Install CCM and Unity on any of them?
Re: MCS7835 difference
It would be simply pointless to mark each model with different IDs if they all do the same don't u think???
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Cisco Unity Supported Platforms List
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd802132ef.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
I should have the following:
1- two CCM Pub and Sub.
2- two unity servers.
3- Unified Presence.
4- Meeting Place.
I already have installed CCM Pub and Sub, should I now check the part-numbers and If it is not mentioned in the above link I should format it and install CCM Pub and Sub on other servers?
and now I can't know the Part-Number because the servers racked and I do not think the Part-Number written on them.
Please advice me.
The install would have simply failed if the servers didn't meet the requirements or were not valid platforms. In any case double check as we define what's supported and not supported based on those links.
You can easily search www.cisco.com for the supported servers for MP and CUPS
java
java
117
