MCS7835-I3 NICs can't get up after upgrade DRAM and version
Dears,
Our MCS7835-I3(Publisher) NICs can't get up after upgrade from 8.5 to 8.6, also we add the DRAM from IBM, "show network status" shows the status is down, and link delected is no, but actually the cable is connected and NIC light is on, interface status on the neighbor switch is up. I tried to use the "set network status eth0 state down/up", but cm told me command is unsuccessful. It seems operating system thought NIC has no links. what is the problem? It is urgent.
Kirin
146
