MD110 E1 2811 MGCP only 1-15 timeslots work
paa
Hi!
I have a strange problem with my Erisson MD 110 and CCM 4.3 & 2811 (MGCP). MD110 connected to 2811 (E1 QSIG), 2811 registered as MGCP gateway. I find out, that no voice in both direction, when calls occupied timeslots after 17.
sh voice call summary
PORT CODEC VAD VTSP STATE VPM STATE
0/0/0:15.1 - - -
0/0/0:15.2 - - -
0/0/0:15.3 - - -
0/0/0:15.4 - - -
0/0/0:15.5 - - -
after
0/0/0:15.17 - - -
0/0/0:15.18 - - -
2811 config:
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn send-alerting
isdn contiguous-bchan
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
mgcp
mgcp call-agent CCM1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp profile default
Somebody know how to fix problem with other 17-31 timeslots?
7 Replies 7
iptuser55
Level 6
Level 6
Is the MD configured for all 30 channels, can teH GW support 30. Also I see you have isdn contiguous-bchan set maybe remove it
Ayodeji Okanlawon
You can do a sh diag ...this will telly ou how many dsps you have. May be you have PFDM2-16, which can only support 16 channels..
Please rate all useful posts
It is not a problem with dsp - I have a PVDM2-32. If I didn't have a enought DSP, I couldn't configure
May be somebody confugured MD 110 to operate with cisco and can help to check MD 110 config?
To check the configuration of the MD in that how many have tehy configured , you could if they have configured correctly ie. CCM uses top down, MD bottom down
Use DEBUG Q931 and ask the MD user to make a call = what does it come on - channel 31 ? ch 1 If it is ch 31, 30 , 29 etc then I guess the MD guy have configured it correctly with the correct number of channels
Every call from MD to ehpone occupied timeslots top-down (1,2,3,...20,21,22,...30,31,1). Every call from ephone to MD occupied timeslots top-down (1,2,3). I find out, that no diffirence in debug isdn q931 between calls from MD to ephones from 1 and 21 timeslots, except no voice in last case.
Hello Team,
Does anybody got the resolution for this. I am also experiencing the same
thanks
