Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Media Resource Group Hunting inside MRGL
Hi Guys,
Problem is my Adhoc conf call uses default resources and not the one that's inside the phone devicepool's MRGL..during testing, I noticed that if I put the HW MRG to a higher order or in top of the SW MRG, it will work correctly. I'm confused by that kind of behavior of why it just wont hunt down on the next MRG inside that MRGL. Plus having a hard time looking for document that can explain it.
Any ideas? thanks in advance
Hall of Fame Super Silver
Media resources within MRG are used in round robin fashion, MRGs within MRGLs are used in top-down fashion.
If this is how you have it and it does not behave correctly, couple of things to check:
check to see if you are using device mobility and roaming DP is used
ensure the media resource you expect to be engaged supports the codec the call is negotiated
media resrouces not added to any MRGs are available to everyone.
HTH,
Chris
And it will only hunt to the next MGR when all the resources from the first MRG are busy, if they're not capable of the codecs you need, but are available, they won't hunt to the next MRG, but the conference will fail.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks Chris and Jaime,
Let me give more details;
Resources
Software CFB
Hardware CFB_A
Hardware CFB_B
inside the Test_MRGL, there's two MRG; MRG_A (top member) and MRG_B (last member)
MRG_A has Software CFB only
MRG_B has Hardware CFB_A only
Test_MRGL hardcoded to IP Phone config
Call flow: IP Phone dials out to PSTN, got connected and uses conference feature to patch in another PSTN number.
If MRG_A is on the top member of the MRGL, it uses the default resource Hardware CFB_B
but If MRG_B is on the top member of the MRGL, it is being used correctly by the conference call.
Question is within the MRGL, there's HW resources available. why it is using the default one?
this test i think is similar to the example given in this link;;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmsys/a05media.html#wp1022428
Any more ideas?
thanks!
I'd start by resetting the CFB or re-starting IPVMS and then try again.
java
java
Can you post your media resource GW config?
Are most CFB configured in the same DP, etc in CUCM? Are they showing registered?
Chris
239
