Community Member
media resource group
hi,
What is the best way to keep media resouces in media resource list.
I want hardware conference bridge to be used only for G.729 calls, for all other conference calls G.711 i want to use software conference bridge. How to accomplish this?
Super Bronze
One option would be to use the software conference bridge on CUCM, or limit your hardware conferences to G711.
Then configure (seperately) a bank of transcoders to bridge G711 and G729.
You can then ensure that the G711 conference MRG is higher in the MRGLs.. this would be used, and if required (i.e. when a G729 user dials in) CUCM will invoke a transcoder session.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Hi Aaron,
I m unable to properly understand what you said because if i use only software conf brdge then conference with G.729 calls will not be possilbe.
Super Bronze
Sure - the software conf bridge supports G711 only.
But if you have PVDMs (as you have said you have hardware conferencing) then they can be configured to do transcoding instead. When someone tries to access the G711-only software conf bridge, CUCM will invoke a transcoder to convert the G729 to G711.
The transcoder would need to be in the same site/region as the software conference bridge for this to work.
Aaron
Community Member
sccp ccm group 9
associate ccm 2 priority 2
associate ccm 1 priority 1
associate profile 10 register TRSKHI-01
associate profile 20 register CFBKHI-01
associate profile 30 register MTPKHI-01
switchover method immediate
switchback method immediate
dspfarm profile 10 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
maximum sessions 2
associate application SCCP
dspfarm profile 20 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
dspfarm profile 30 mtp
codec g711ulaw
maximum sessions hardware 2
Thanks Aaron. Looking at config above only 2 transcoding sessions will be very less. What changes do you suggest in
the above config.
Hall of Fame Super Silver
Remove all codecs except for g711 from the profile 20 conference or remove the profile completely and you will be able to increase number of transcoding sessions significantly.
HTH,
Chris
434
