Media Resource issue
<p>Hi,</p>
<p> </p>
<p>Running UCM 6.1.2 custer.</p>
<p> </p>
<p>Having 3 locations.Two locations are having local Callmanager group and other location having SRST. There are two Media Resource Groups are configured.</p>
<p> </p>
<p>SRST location and one loaction are sharing same Media Resource group with different Device Pool. In SRST location MeetMe and Ad-Hoc conference working fine but  other location it's not working(the Media Resource are local for this location).</p>
<p> </p>
<p>If i select second Media Resource Group for this location, MeetMe and Ad-Hoc conference works fine.</p>
<p> </p>
<p>Please help me out!!!</p>
<p> </p>
<p>Regards,</p>
<p> </p>
<p> </p>
Re: Media Resource issue
In the location where things aren't working....what's there?  A CCM server?  A Router?
Are you using software or hardware resources for conferencing....and where are these installed?
check the codecs being used, SW CFB can only handle G711
Java
If this helps, please rate
java
if this helps, please rate
www.cisco.com/go/pdi
Using only Software conferencing bridge.
First location Publisher & 1 subscriber installed, second location 1 suscriber installed and third location SRST routers installed.
Media Resource Group is comman for Location 1 & 3. But in location 1 where the CCM are installed Conferencing is not working,but selecting other Media resource group (created for location2),conferencing will work fine.
Between the regions using G729 codec.
DO you have transcode resources configured? The software based conference bridge will not support anything but G.711. If you're running resources that are having to connect between locations via G.729 based on locations/regions settings, it won't work without transcode resources in place, and those are only done in hardware.
VIP Super Bronze
With SW conference bridge, you need to makesure that the region your CFB is in and the location is using G.711 beaciuse this is the only codec that is supported
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
189
