Community Member
Media resource list / group question
If I setup a Media resource list with multiple Media resource groups and each group is its own media resource. Will I use all of my resources from one group before I move to the next. Or once it hit a % will it start pulling from the next group? Thanks any documentation would be great
Re: Media resource list / group question
When its unvailable or full, it will go the next resource. There is % threshold to configure for it "roll" to the next resource.
resources are allocated in round robin within the MRG, if no resources are available in the 1st MRG from the MRGL then CUCM will look into the next MRG and so on until all MRGs are exhausted
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Where do I config the %?
thanks
NOT configurable
java
java
Like Java said, you can NOT configure by percentage.
342
