Medianet and per-port/per-vlan QoS policies
jkeeffe
Level 2
Level 2
On page 2-7 medianet Campus QoS Design 4.0, it describes per-port/per-vlan QoS policies as being for trunk ports only.
If a PC is plugged into an IP phone into a single switch port, and the phone and PC are on different vlans - is that considered a trunk port?
Here is a typical port config we use:
interface GigabitEthernet1/15
switchport
switchport access vlan 6
switchport mode access
switchport voice vlan 910
mls qos trust dscp
spanning-tree portfast
Marwan ALshawi
This port is special type of access ports where it accept traffic from two different vlans
But if you use per vlan policing and you apply the Command  mls qos vlan-based then qos policy applied on the relevant vlan interface will take effect
Hope this help
