MediaResourceListExhausted!!!
Hi All,
Today the calls are getting dropped and when I looked the RTM Alert, I saw the below info, is it because of this that the calls are dropped.
Calls are getting connected once in every 3 times only.
Most Recent Alert Raised: At 16:47:49 on 06/01/2007 on cluster StandAloneCluster.
Number of MediaListExhausted events exceed 0 within 60 minutes.
There are 4 MediaListExhausted events (up to 30) received during the monitoring
interval from 16:21:51 06/01/2007 to 17:21:51 06/01/2007:
MediaResourceListExhausted Originated from CallManager
Device Name: AAA_Media_Group
Device Type: Transcoder
CodeYellowEntry AverageDelay : 681 EntryLatency : 20 ExitLatency : 8
SampleSize : 10 TotalCodeYellowEntry : 546 NormalPriorityQuequeDepth : 9
HighPriorityQueueDepth : 1 NodeID : A.B.C.D
At 19:23:05 on 08/20/2007 on node A.B.C.D.
Available memory below 10 Percent. DCX500 (86 MB) uses most of the memory.
Most Recent Alert Raised: At 17:36:01 on 08/20/2007 on cluster StandAloneCluster.
Number of RouteListExhausted events exceed 0 within 60 minutes.
There are 1 RouteListExhausted events (up to 30) received during the monitoring
interval from 17:16:45 08/20/2007 to 18:16:45 08/20/2007:
RouteListExhausted Originated from CallManager
Route list name: AAA PSTN Route List
At 13:50:27 on 08/20/2007 on node A.B.C.D. Service status is DOWN .
The following service(s) are down: Cisco CTIManager.
658
