Silver
MediaSense
Has anyone be able to install mediasense correctly?
I have set up a lab, and with callmanager 8.5.1 and mediasense 8.5.4
In the mediasense setup wizard, it asks for  an AXL provider with username and password.
I use the administrator password from callmanager (which has AXL role) but the wizard constantly tells me that soemthing is wrong:
And I very sure that the information is correct, the same information is used for my demo UCCX 8
Any idea?
JH
Everyone's tags (1)
MediaSense
Couple of things to verify.
1. Check if the AXL service is running in CUCM?
2. Check for case sensitivity both in the Username\password.
3. Is your CUCM reachable ?
Hope it helps.
Anand
Please rate helpful posts !!
Silver
MediaSense
Hello Anand,
Thank you for your quick response
Let me do some more checking.
I will reinstall UCCX 8.5 and see if it connects correctly to my CM with AXL
My demo period has epired for UCCX 8.5
Jan
Silver
Re: MediaSense
Hello Anand,
After a reboot of everything it works, I have installed everything on an ESXi and maybe things were a little confused.
Works now,
Jan
Re: MediaSense
Hi Jan,
Glad to know that :-)
Please rate postings if they have helped, by clicking on the stars below them.
Anand
494
