Meeting Place express 2.1.2 compatibility with exchange 2010?
Hi guys,
I have a problem with MPE 2.1.2 which is integrated with Exch 2010.
When I am testing the integration form the "Exchange Server Configuration" page the system says it is ok and I can see the test email in the users mailbox.
When I try to schedule a meeting, the mails are not send to the invitees and I can see in the "E-Mail Notification Queue Status Report " the mail that it is trying to send. This tells me that the mail never leaves my MPE.
Does anyone know if MPE 2.1.2 is compatible with Outlook 2010?
This are the errors I see when MPE is integrated by Exchange page
10/12 11:35:10:00WARN131325csconfrec.cc5354(7,169,1,2)Scheduler 7 not found in invitee list for conf 169
10/12 11:35:10:00INFO131357csschedparams.cc3009(11,0,0,0)Schedulable Voice Ports = 11
10/12 11:34:44:00WARN2097154mp_calls.cc4394(-1,0,0,0)Call failed, error = -1
10/12 11:34:44:00WARN2097153mp_calls.cc2317(0,0,0,0)Invalid input params
This are the errors I see when MPE is integrated by  page
1 ACCEPTED SOLUTION
Re: Meeting Place express 2.1.2 compatibility with exchange 2010
Outlook Integration Requirements
If your system integrates with Microsoft Outlook, Cisco Unified  MeetingPlace Express requires the following:
Microsoft Outlook 2000, 2002  (XP), 2003, or 2007 Service Pack 1 or 2
Note We do NOT support Microsoft Outlook  2010.
Microsoft Exchange 2000, 2003  Service Pack 2, or 2007 Service Pack 1
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/meetingplace_express/2_1/b_rn21.html#wp245263
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
This are the errors I see when MPE is integrated by  SMTP page
10/12 11:13:47:00MAJ2162719poclientthread.cc2783(4,0,0,0)POC: Retries failed, Check Mail server configuration
10/12 11:13:07:00WARN2162712emailtemplate.cc2079(19,5,0,0)POC: Email Not Sent, SMTP Servers are unavailable
10/12 11:13:02:00WARN983179pombox.cc1738(3,0,1286871182,1286815887)PO mailbox unread more than 2 hrs. Mbox 3, NumMsgs 0, now 4cb4188e, last 4cb3408f
10/12 11:13:02:00WARN131325csconfrec.cc5354(7,167,1,2)Scheduler 7 not found in invitee list for conf 167
10/12 11:13:02:00INFO131357csschedparams.cc3009(11,0,0,0)Schedulable Voice Ports = 11
I have checked the smtp server and everything seems to be ok. I can telnet to that server and send mails
java
java
1302
