06-18-2012 10:48 AM - edited 03-16-2019 11:43 AM
Hello
It is possible to do a SIP Integration between an Avaya PBX and a Meeting Place ???
Best regards
06-18-2012 07:56 PM
No testing has been done for interop of Avaya and MP. Due to this we do not have any documentation.
But you can have CUCM in between and integreate CUCM to Avaya and CUCM to MP and things will work.
For Avaya and CUCM sip integratin you can use following link
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns784/705625.pdf
Ronak Patel
Rate helpful posts.
10-04-2012 10:35 PM
Our Company is an Avaya shop but to integrate between the Avaya system(s) and MeetingPlace we have CUCM. This allows CUCM to download MS Active Directory and then upload this database to MeetingPlace. I have h.323 and SIP trunks from all of the Avaya Systems to CUCM and then a SIP trunk to MeetingPlace. CAC is basically the IP-Network-Region settings on the remote Avaya since not all calls go to CUCM. It isn't pretty but it works.
Joe
