MeetingPLace 6.x Port question
I have 54 conf ports. I want to configure the system to do this:
11 conf ports
1 overbook port
1 contingenct port
41 floater ports
The reaon I want to try this is to have everyone schedule max 1 port and use the floating ports as needed.
The problem i have is when I configure the number of floting ports higher than conf ports I get an error when scheduleing a meeting. It says there are no ports available to schedule the meeting.
Any ideas if I can do this?
Randall
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: MeetingPLace 6.x Port question
Hi Randall,
My understanding of this is that Floater Ports are used in relation to "Reservationless" Meetings and Overbook Ports are used in relation to "Scheduled" meetings. So for your config I would think you need to re-assign the Floater Ports as Overbook Ports instead :)
Remember the following information:
•Make sure the total number of scheduling ports available (including overbook ports) is equal to or greater than the largest meeting size you expect to schedule.
http://www.cisco.com/en/US/docs/voice_ip_comm/meetingplace/6x/audioserver/administration/guide/6xmpasag020.html#wp1054578
•Reservationless meetings are best served by a small starting meeting size and a larger floater pool, with little or no overbooking
•With scheduled meetings it is best to set the default meeting size to the average (which is typically about 5), and use overbooking to compensate for no-shows and cases where reservations are higher than actual usage.
http://www.cisco.com/en/US/docs/voice_ip_comm/meetingplace/7x/english/planning/licensing_about2.html#wp1067025
Hope this helps!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Hi Randall,
Hope this helps!
Rob
Rob,
You are so the Man!
Thanks for your help!
Randall
Hi Randall,
You are most welcome my friend! Thanks for your very kind words and nice rating to boot.
Cheers!
Rob
150
