Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Meetingplace 8.5 Web Server download
Trying to find 8.5 version of Web Server component.
Doc says that I should be able to find this. But I cannot see this.
"If you are planning to install Cisco Unified MeetingPlace Release 8.5.3, then go to
http://www.cisco.com/cisco/software/navigator.html and select Products > Voice and Unified
Communications > Unified Communications Applications > Conferencing > Cisco Unified
MeetingPlace > Cisco Unified MeetingPlace 8.5. Obtain
CiscoUnifiedMeetingPlaceWebServer.exe file for Release 8.5.3."
Does anyone know where is the correct spot?
Felix
1 REPLY
Scratch That
it's filed as Cisco Unified MeetingPlace Web Conferencing
662
