You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
MeetingPlace 8 Auto Attend Feature
Hello
I have enabled Auto Attend feature for my user.
I can see the User Profile has the 'Main Number' field with 6983 which matches the extension
I schedule a meeting from Web Interface
I call meetingplace using endpoint 6983
I'm still presented with :
press 1 if you know the meeting ID
press 2 if you want to start a meeting
press 3 to access your profile
if I press 1 and enter the meeting details, and I check the Meeting Invitees from the Web Interface it shows up as Guest.
I must be missing a checkbox somewhere or am I not understanding this feature?
Felix
  • IP Telephony
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hi Felix,
Could you please check the below parameters are configured?
-Meeting profile match the main phone number
-Auto attend mode set to "automatically join meeting
-Allow any profiled user to initiate set to "yes".
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
Hi Felix,
Tere.
Re: MeetingPlace 8 Auto Attend Feature
Hi Tere,
Thank you. After checking your suggestions I found out that the main issue is with this particular user.
What I notice is that sometimes the Main Number field in his profile is 'Blank'
However when I checked in CUCM the number is there!
I have to perform a full sync again from Directory Service page.
Do you know what could be the cause?
Felix
Nevermind I found the DDTS:
CSCti48222
Which should be resolved in 8.0.2
289
