Meetingplace express 1.2.0.111
I'm looking for a method to retrieve disk space on the db partition. Tried using the file cleanup utility which didn't retrieve any space. The error received prior was "not enough disk space" when attendees tried to record their names for the meeting. The error is intermittant and is reproduced more than once for the same meeting while at the same time other attendees for this meeting don't generate this error.
NB
1 REPLY
Silver
Re: Meetingplace express 1.2.0.111
Modified the proxyName value by adding the .uss.com to the end of it in the server.xml file located in the following directory of MPE:
Documentation for 1.2.0.111:
http://www.cisco.com/univercd/cc/td/doc/product/conf/mpe/v12/index.htm
140
