Meetingplace Express 2.0.3.35 & outlook
I can't install outlook plugin. When I try to install appear a message tha says: "Setup encountered an error during copying the form file 0x80070003". According to Cisco the problem it with system default language. There are something to resolve this problems without change de system language.
Re: Meetingplace Express 2.0.3.35 & outlook
When you download the plugin, rename it to setup.exe and then save it and run it.
this is the plugin's name (setup.exe). the office version it 2003. the problem continue.
regards
Did this get resolved?
148
