MeetingPlace Express - adjusting clock
pijssel
Hi all,
I just installed a MPX 2.0 server and it runs fine. But now I want to change the time on the server, because I misconfigured it in the first step...
I read in the documentation that it is not possible to change the clock without reinstalling the MPX server.
Does anyone know how I can change the clock without haveing to reinstall the whole server?
With kind regards,
Paul van den IJssel
Digacom
The Netherlands
thisisshanky
Level 11
Level 11
If I remember right, you can use the "net" command from CLI to configure time.
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Nope, I allready tried this :(
bill.watts
If you run the net command and select Option 8 do you see any listings for time servers? If not, you can set up to 3 NTP servers to point to.
david.mackill
Hi, I just did this.
SSH into the MPX box (or open a terminal session) elevate yourself to root level (type: SU)then use the date command to change the time:
# date -s "16:15:00"
then reboot the server (type: reboot)
after that the MPX server displays the correct time.
tested on version 2.0.3.35
