10-22-2008 04:00 AM - edited 03-15-2019 02:05 PM
hi everybody
i have a CMBE6. i need to configure meetme with unity connection as conference bridge, means when users logs in to the conference his/her name should be read. is it possible?
can anyone give me an idea regarding this?
thanks in advance
Solved! Go to Solution.
01-28-2015 06:00 PM
1) You would need to adjust the VM ports or SIP trunk to not be able to reach the meet-me DNs and/or the restriction tables, or hardcode the transfer with caller input to just certain meet-me DNs..
2) You cannot modify that behavior.
01-28-2015 10:42 PM
Jaime,
Sorted out the partitions and CSS, I had forgot about the CSS on the VM ports in CUCM, so its all working.
So there is no way of changing the option 2 to reject the call and hang it up instead of leaving a VM?
01-23-2014 05:59 AM
Fantastic Post
Did it and it worked
Shameer
06-29-2017 02:50 AM
Hello Jaime, its really nice information
Actually I am working on 1 of my client issue where cucm corrupted and lost drs too because of which we have to build entire setup
Customer is saying they use to have Meet me number 4050 to 4054
host will dial 4050 and goes in mute, Internal participants will dial 2095 and enter the passcode. external participants will dial XXXXXX0095 and enter passcode to join. Maximum 8 participants
They have achieved this using call handler(bcz customer said they use to change the passcode in unity), I am really have zero knowledge on hot to configure this. Is there any way you can tell me step by step on how to achieve this solution, I am really stuggling to get this done.
06-29-2017 08:58 AM
No way this could have worked that way, neither CUCM nor CUC have an option to enter a passcode to enter the meeting.
CUC was only used as a front end for the meet me so the user was announced and he could be granted/denied access to the meeting.
06-29-2017 09:06 AM
Do you think caller input under edit can be manipulated in such way
06-29-2017 09:10 AM
No, caller input is only ONE digit (0-9), more than one digit, will be handled as an extension.
There is no way this could have worked the way they said (at least not with just CUCM and CUC).
06-29-2017 09:12 AM
ok fine thanks for your reply Jamie
11-11-2014 02:07 AM
Hi, Sorry to drag this topic up from the dead. Does anyone have a solution for this issue when the MeetMe is not initiated? For example, when the MeetMe is not initiated yet, I would like to to play hold music while waiting...I have not been able to find a solution for this, so any comments would be appreciated! Thanks all
11-11-2014 07:34 AM
I don't think that's possible, you need to have the meetme up and running before you attempt the transfer or it will fail. Just as you cannot put someone on hold if they dial the meetme before it starts.
