Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Meetme enter/exit tone
Is there a way to set a different exit tone when a caller hangs up from a meetme conference than the enter tone when someone connects to a meetme conference.
By default it is the same tone when someone connects to the meetme as when they disconnect. This seems to be confusing to some users and I would like to change it if possible.
Thanks.
1 ACCEPTED SOLUTION
Re: Meetme enter/exit tone
unfortunately it's not possible, the tone is generated and is the same one. the system refers to the same tone and cannot be changed one for new comers and one for guys logging out
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
117
