Meetme max users issue CUCM 9.1.2
Hi Guys,
I have a new installation of cucm 9.1.2 in a cluster of four servers (1 Pub and 3 Subs) and I configured just a regular meetme number, the issue that I have is that I already changed the Maximum MeetMe Conference Unicast parameter value under the Clusterwide Parameters (Feature - Conference) from 4 to 10 but the system is only allowing 4 uses in the meetme conference.
I have already verified my SW CFB, HW CFB, MRG and MRGL configuration and I have enough resources to have more than 4 users in the meetme conference, I did a "normal" conference adding users from a phone and I was able to add up to 10 (wich is the value that I configured under the maximun ad hoc conference parameter).
What do you think can be causing this????
Thanks in advance for your comments.
Which CFB are you using?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hello Jaime,
I have configured a MRG with the SW CFB that the CUCM has by default and a MRG with two HW CFB configured like this:
dspfarm profile 1 conference video guaranteed-audio  (I have video phones)
codec ilbc
codec g722-64
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec h264 cif
maximum sessions 16
associate application SCCP
In the MRGL I have the HW before de SW, if I make a normal conference with a phone I can add up to 10 members...the issue seems to be just with the meetme.
One thing that I noticed is that when I make a conference, the phones are not using the hw resources instead the sw ones, I removed the MRG SW from the MRGL and then the phones were using the hw resources.
The order that I have configured is HW and then SW in the MRGL.
At the end the issue was that in the HW CFB was not configured the "
maximum conference-participants", I configured that and then it worked ok with 8 users:
codec ilbc
codec g722-64
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec h264 cif
maximum conference-participants 8
maximum sessions 8
It seems that the SW CFB only support 4 participants per conference, right?
553
