08-08-2012 08:13 AM - edited 03-16-2019 12:36 PM
I trying to increase the maximun number of call that Meetme can handle but after the 6th call is made a fastbusy tone is received. I have followed the next steps:
1. Increased the Maximum MeetMe Conference Unicast parameter to 10
Service Parameters->Maximum MeetMe Conference Unicast:10 for all Call Manager server
2. Hard/Software Conference are available for use for meetme conference:
CUCM
IOS Conference Bridge Info
Cisco IOS Enhanced Conference Bridge | |
Device is trusted | |
CFBCUBE | |
CFBCUBE | |
Default | |
HQ | |
Router#sh dspfarm dsp all
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 15 26.8.1 UP N/A FREE conf 2 - - -
0 16 26.8.1 UP N/A FREE conf 2 - - -
0 17 26.8.1 UP N/A FREE conf 2 - - -
0 18 26.8.1 UP N/A FREE conf 2 - - -
Thanks in advance.
Solved! Go to Solution.
08-08-2012 09:13 AM
Most likely you're using the HW CFB and the number of conferencees is limited due to the codecs under your dspfarm configuration.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-08-2012 08:27 AM
Did you place the conferencing resources in the MRGL of the user who initiated the Meet me call ? Please do it if not done already and let me know if it resolves the issue.
Arun Kumar
Please rate useful posts.
08-08-2012 08:42 AM
Yes, the conferecing resources are place in the MRGL of the user.
08-08-2012 09:13 AM
java
08-08-2012 09:17 AM
Hi Leo,
I'm going with my friend Java here Have a look at the restrictions shown in this
doc with Hardware Conference Bridges;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmsys/a05confb.html#wpxref27448
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
08-08-2012 11:21 AM
I'm using both HW/SW Conference resources. For DSP it used a Cisco 3945 CUBE with G.711 CODEC so which should be the maximun number of participant?, the link only show the restricction for Cisco Catalyst.
08-08-2012 11:45 AM
Please post your dspfarm config and how are your MRG/MRGLs configured?
Which CFB do you use in first place?
java
08-08-2012 02:07 PM
I used in first place the harware conference bridge.
CUBE 3945 setup:
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate ccm 4 priority 4
associate profile 2 register CFB_1CUBE
associate profile 1 register XCODE_1CUBE
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
show run | s dsp
dspfarm
dsp services dspfarm
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 90
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 40
CO01CUBE#
CUCM
CUCM
HQ_MRGL
HQ_HW_MRG
CFB_1CUBE CFB_1CUBE
CFB_2CUBE CFB_2CUBE
CFB_1CUBE CFB_1CUBE
CFB_2CUBE CFB_2CUBE
SW_MRG
CFB_1CUBE CFB_1CUBE
CFB_2CUBE CFB_2CUBE
CFB_1CUBE CFB_1CUBE
CFB_2CUBE CFB_2CUBE
08-09-2012 04:53 AM
I realized that I was missing the command: Maximun conference-participant so now the conference ad-hoc are working but the Meetme is still not working.
After some looking, I realized the Meetme is using the MCU Media resources so maybe there's a way to increase the number participant for the MCU.
