meetme - organizer leaves all calls go down
hi,
I have meetme working just fine.
I want so that when the organizer hangs up that all calls disconnect from that meetme.
any way?
does this same thing apply also to ad-hoc conf call?
thanks.
No, the meet-me doesn't go down unless everyone drops the calls.
The parameter to keep conferences if the initiator drops, or to drop it if he drops the call, are for ad-hoc
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
all right can you tell me the parameter for ad-hoc?
also, any way to setup a password in meetme?
or any way to close the meetme so that no one else can jump into the meetme conferance?
thanks.
Re:meetme - organizer leaves all calls go down
Meet me and pwd has been discussed thousands of times before, no, alternatives can be found on previous CSC threads
Sent from Cisco Technical Support Android App
java
154
