Community Member
MeetMe strange request on CUCM 6.1.2
Hi All,
My customer here needs when leaves meetme conference all other participants who had joined the conf. to be dropped,the same like AD HOC conference.
I have CUCM 6.1.2
Any Ideas,
Ahmed Kamal
Re: MeetMe strange request on CUCM 6.1.2
Hi Ahmed, The CUCM does not support that feature with MeetMe. It only works with Ad Hoc conference. I hope this helps. Marcos
This may be possible if the individual is the meetme conference initiator. I have not tested this but it is the only way i am aware of that might possibly allow your desired workflow.
CM Service parameters off the option to maintain or drop a conference when conference originator leaves the conference.  Set this option to drop conference when originator leaves.  Then make sure your user is the meetme conference initiator.  It's worth a test.  If it does not work then I believe Marcos' point about adhoc behavior definitely follows the behavior configured in this service parameter.
184
