09-10-2013 10:02 AM - edited 03-16-2019 07:17 PM
Recently took over a CM 9.1 system. Have had a little training on cm/unity so I am learning as I go.
When I press the Messages button, it tries to call 2999 and I get a message that the call cannot be completed as dialed. I am gone into call manager and see the port used by Unity as 8001. I can reach that number and get into voicemail.
Not sure how to fix/recreate getting 2999 to forward to 8001 or how to change the Messages button to call 8001 directly. I have gone through the books I have and not seeing what will help me fix this.
Ron
09-10-2013 10:19 AM
Check the Partition and css of phone & voice mail port.
Gnan.
09-10-2013 10:45 AM
Looked at unity - it is set for the same css and partition as the phone in question. When I tried calling phone A from phone b and not answering phone b, it would rollover to voicemail from that method either.
09-10-2013 10:23 AM
Change the VM pilot from the VM profile to dial what you need.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-10-2013 11:54 AM
How Jaime suggested, verify in CUCM configuration that voicemail pilot DN in voicemail profile is 8001
Carlo
