Message From Unknown Number
My network scenario is a CallManager 5 connected by a bri interface with a Cisco 2811, IOS Version 12.4(9)T6, to a PBX.
When I make a call from the PBX side to the VoIP side i get the "From Unknown Number" message on the voip Phones (Cisco IP Phones 7961 or 7941 series).
I believe this is somehow worked around in the gateway, maybe by adding the command caller-id enable on the voice ports, but this does not seems to be available...
Does anyone knows if I'm right or wrong in this... and if I'm wrong how can I solve this issue?
If you need any more information, please tell me, and I will post it :)
Best Regards,
Ricardo Rolhas
Hall of Fame Super Gold
Re: Message From Unknown Number
let's see first if the PBX sends the calling number.
"Debug isdn q931" and "Term mon", will tell you if it does.
Here is the debug, for you to analyze.
It sends the nember it has dialed, but I don't see any info about it's own number.
I dialed 309 on the pbx side, this is what I get in the debug:
Dec 6 13:54:36.965: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8583 - Origination address is non-ISDN
Calling Party Number i = 0x00C3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '3'
Plan:ISDN, Type:Unknown
Dec 6 13:54:36.989: ISDN BR0/0/0 Q931: TX -> SETUP_ACK pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
Dec 6 13:54:37.185: ISDN BR0/0/0 Q931: RX <- INFORMATION pd = 8 callref = 0x01
Called Party Number i = 0x81, '0'
Dec 6 13:54:37.421: ISDN BR0/0/0 Q931: RX <- INFORMATION pd = 8 callref = 0x01
Called Party Number i = 0x81, '9'
Dec 6 13:54:37.429: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Dec 6 13:54:37.449: ISDN BR0/0/0 Q931: TX -> ALERTING pd = 8 callref = 0x81
Progress Ind i = 0x8088 - In-band info or appropriate now available
Dec 6 13:54:42.565: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
Cause i = 0x8590 - Normal call clearing
Dec 6 13:54:42.573: ISDN BR0/0/0 Q931: TX -> RELEASE pd = 8 callref = 0x81
Dec 6 13:54:42.625: ISDN BR0/0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
Best Regards,
Ricardo Rolhas
283
