Message notifications by mail without extending eschema AD
Is it possible to receive notification just to be informed that there is message and the number that where the call is from?
The reason is that there is no access to modify the schema AD.
Green
Re: Message notifications by mail without extending eschema AD
If using Unity they have something called message notification, in Unity vm only you can configure an Email server relay in your Exchange to fwd messages to a different Email server. In CUCM not possible with default features.
Hi Thanks a lot for your recommendations
Where can I find that procedure???
regards
Green
Hola Alfredo
Checa esto por favor:
Basicamente necesitas que tus correos en cierta cuenta se forwardeen a un servidor externo de correo que los entregue (smarthost)
http://www.christensen-software.com/support/config_exchange_2000.htm
Gracias
ok muchas gracias lo voy a checar
261
