message wait indicator -- always lit
Hi All,
Need a hand on this.
Problem description :
Single user -- facing an issue -- having no voice-mails in his mail box-- yet the MWI is always lit .
Troubleshooting done : Reset All option on the cisco unity connection page -- for the user # no success.
CUConnection version : 6.1.x
Whatever level you reach getting better never stops -- Sachin Tendulkar
Bronze
Couple of quick questions that have helped me narrow this down in the past:
Are you sure that the user doesn't have a shared line on their phone?
Can you manually turn off the MWI by using the MWI off DN?
Hey Gareth,
Can you kindly let me know, where we find the option for MWI off DN
There's no CUC version 6.X
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
sorry for being so abbreviated,  i meant ..cisco unity connection
Dialling the MWI-Off # worked for us.  The line did not have a Unity account associated to it, but the Voice Message light was on.  This was bugging me for days.  Thank you.
Hall of Fame Super Red
Hi Abhishek,
Like Gareth nicely noted (+5 )
Go to the phone or have the user dial the MWI-off number
from the proper line button;
To find the MWI-On and MWI-Off numbers from CUCM admin;
Feature> Voicemail> Message Waiting> Find and List
Cheers!
Rob
"Everything is broken" - Bob Dylan
dialling the MWI off number did not help , as well as the user does not have a shared line
eeh..ohhh.. the mwi off number 's css didn't have the partition of the phone line. Resolvedoooo
Re: message wait indicator -- always lit
Hi Abhishek,
Nice troubleshooting my friend + 5 for posting back with your results here.
Cheers!
Rob
Thanks Rob... for the love of IP Tring...Tring..need to learn more
All the above and also from Unity it is sometimes worth re-synching the MWI status from there.........
1376
