Message Waiting Indicator (MWI)
We have a CUCM and a 3rd party Voice mail system. We have no issues with voice messages, however we want to enable the MWI indicator in the Cisco IP Phones.
From 3rd party voice mail system, we are sending SIP Notify command as "Messages-Waiting:yes" and CUCM also acknowledges with 200 OK.
However the MWI is not getting enabled. Is there any other option to enable or the command need to be changed ?
FYI: In the CUCM Service parameters, by default Light & prompt is enabled for Message Waiting indicator.
Can someone help me on this please.
Prasana
Regards, Prasana Kumar.P +919841027006
11 Replies 11
Did you get a chance to have a look at the CUCM traces? As SIP being used and you have also mentioned that the SIP Notify message body containing Messages-Waiting:yes is being sent by the 3rd Party VM system.
So, CUCM should also send the same notify message to the phone with Messages-Waiting:yes so as to light up the notification.
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Hi Abhay,
I have taken the Wireshark capture of the SIP traces. Can you please check and advise..
Prasana
PCAP analysis :-
Session Initiation Protocol (NOTIFY)
Request-Line: NOTIFY sip:5010@10.125.111.145:5060 SIP/2.0
Message Header
Via: SIP/2.0/UDP 10.125.111.224:5060;branch=z9hG4bK1b81bc37129
To: <sip:5010@10.125.111.145>
Call-ID: 2e021300-92b19ae7-184-e06f7d0a@10.125.111.224
CSeq: 101 NOTIFY
Sequence Number: 101
Method: NOTIFY
Max-Forwards: 70
Date: Mon, 29 May 2017 03:52:07 GMT
User-Agent: Cisco-CUCM11.0
Event: message-summary
Subscription-State: active
Contact: <sip:5010@10.125.111.224:5060>
Content-Type: application/simple-message-summary
Content-Length: 22
Message Body
Messages-Waiting: no\r\n
As per the notify message above, message body contains "No" for the Messages-Waiting. Due to this MWI is not working.
I hope the CUCM IP address is 10.125.111.224 and IP Phone is 10.125.111.145. Correct me if I am wrong.
Abhay
Abhay Singh Reyal
Hi Abhay,
May be you have seen the first SIP trace. You can see the other SIP Notify as below:
    Request-Line: NOTIFY sip:1001@10.125.111.224 SIP/2.0
        Method: NOTIFY
        Request-URI: sip:1001@10.125.111.224
        [Resent Packet: False]
    Message Header
        Via: SIP/2.0/UDP 10.125.111.145:5060;branch=z9hG4bK-524287-1---e360b935ba5a763d;rport
        Max-Forwards: 70
        Contact: <sip:5010@10.125.111.145:5060>
        To: <sip:1001@10.125.111.224>
        Call-ID: OFG8Wrd5wn3_azbWQcb6jw..
        CSeq: 1 NOTIFY
        Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, SUBSCRIBE, UPDATE, INFO, MESSAGE
        Supported: replaces, timer, norefersub, answermode, tdialog
        User-Agent: UMB
        Content-Length: 22
    Message Body
        Messages-Waiting:yes\r\n
The CUCM and IP Phone address mentioned is correct.
regards,
Prasana
Hi Prasana
After going through the PCAP. the above message is from Phone to CUCM for different call id ie different Subscribe Notify call ID. Whenever MWI is required Notifier (ie phone) subscribes to the CUCM for message-summary event with a call-ID which will be used for all other notify message for this event.As we can see the latest message from CUCM(notifier) to phone (subscriber) is message-waiting: no. That could be the reason phone does not show MWI..
If you could provide CUCM logs where we can review notify coming from 3rd party and going to phone.
Hi Saurabh,
Thanks for the inputs. please advise how can i capture the CUCM logs ?
I can make one more test from 3rd party to send SIP Notify messsage to CUCM and send the wireshark capture. Will it be OK ?
Prasana
Hi Prasana
refer this doc
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200787-How-to-Collect-Traces-for-CUCM-9-x-10-x.html
the process is same for 11.x
enable only sip traces.
And Wireshark capture won't solve the purpose as we have to look the behavior of CUCM wrt to MWI
make a call to Voice mail and then send MWI back. the trace should have this full call flow
Jonathan Schulenberg
Does the SIP Trunk Security Profile from VM allow out of dialog notify messages? Take a look at the Unity Connection SIP integration guide for comparison.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/integration/guide/cucm_sip/cucintcucmsip/cucintcucmsip060.html#27455
Hi Jonathan,
Thanks for your reply and as though there is no SIP Trunk between the CUCM and Voice Mail. We use SIP Extensions as Voice channel and through which the SIP commands are sent to CUCM.
Prasana
Extensions as in a 3rd Party SIP Phone and Directory Number? If yes, why are you doing a line-side integration instead of a trunk? I doubt CUCM will accept unsolicited notifies line-side for another DN. Also, using a 3rd-party SIP device will limit the number of concurrent calls.
Hi Jonathan,
It is the 3rd party vendor where using this approach of SIP Extensions instead of SIP Trunk. Since the SIP Notify command is acknowledged by CUCM, we are checking if there could be any other way of passing or dialing to MWI DN to enable the indicator for the required Extension Number.
Prasana
